Next oil leak
Old May 14, 2020 | 07:27 PM
merebel's Avatar
Default Next oil leak
Well now that oil pan is redone with new front cover seal and oil pump that leak is resolved.
now on to the next one :-(
the power steering is leaking dropped about a 1/4 of the tank in 3 weeks. Now that the front of the motor is not leaking I can clean it up again and look at it. Pretty much the oil is on the lower part of the vehicle, I don’t see any at the top side of engine or by the tank.
Old May 14, 2020 | 07:45 PM
KernowDiscovery's Avatar
Could be your seals. If you're handy enough and don't mind working on it yourself there are rebuild kits for sale. I let mine go dry (don't recommend) and that's when it started making a chewbacca noise. In hindsight I probably should have replaced the pump but eh, it was rebuilt, sound a little whiny but is still running fine seven years later.
Old May 14, 2020 | 07:59 PM
merebel's Avatar
How bad is it to replace the seals
Old May 14, 2020 | 08:05 PM
Extinct's Avatar
90% of the time the leak is the gasket in back. Abbes performance has them for $9 plus $4 shipping
Old May 14, 2020 | 08:06 PM
merebel's Avatar
in back of the pump? Or box?
Old May 15, 2020 | 07:36 PM
Extinct's Avatar
Back of the pump.
Land Rover Gasket of Pump assisted steering + photo tutorial
Old May 17, 2020 | 01:49 PM
cvhyatt's Avatar
I just replaced my pump and power steering lines. About a 4 hour job and glad I did the hoses too because they were badly corroded.
Old May 18, 2020 | 10:13 AM
Jason_B's Avatar
Same. The more stuff you remove, the easier it gets with those lines. They extend all the way in the front of the bumper.
ttownthomas
May 5, 2020 07:34 PM
joshrp5
Nov 14, 2016 05:04 PM
Pjpax
Sep 2, 2014 11:22 AM
Extinct
Apr 1, 2013 09:36 PM
kfox77
Apr 25, 2009 01:29 PM
