No brake lights and shifter solenoid not working
Got stranded yesterday after parking my 2000 D2 at a store. Shifter wouldn't come out of park and I have no brake lights. I checked all the fuses even under the hood, good. The brake switch has continuity between 2 of the 3 pins when the plunger is extended (brake applied). The shifter lock solenoid didn't make any light "click" sound when activating the brakes and when I pulled the shifter cover I had to manually push in the solenoid lock pin to be able to shift out of park and limp home with hazard flashers going. UGH!
Can someone point me in the right direction on where to even start looking for this new gremlin?? Anyone have a similar issue?? I ordered a new switch to test to see if it was the switch.
Thanks for any advice,
Mike
Mike
The Deputy (05-03-2021)
Received 1,189 Likes
on
Best4x4 (05-03-2021)
