brake switch replacement
Old Aug 4, 2012 | 03:21 PM
A5scott's Avatar
Default brake switch replacement
I bought a new brake switch and i feel like i have it secure in place. I orientated the fins to the slots pushed in and rotated 90 degrees, while the brake pedal was pressed a bit. I snapped the electrical connector back in and my brake lights are constant on. Is it a fuse that is also blown? if so, where is the fuse? under the hood in that big fusebox? or did i F it up by maybe touching the plunger
i did not put the shifter back together yet, and i tried shifting out of park, but it wouldn't shift. does the shifter need to be reassembled to work again? I just want to be sure because I'm disabled and am not strong enough to pull the shift **** off...
thanks again
Old Aug 4, 2012 | 03:47 PM
A5scott's Avatar
ok, so I pull the plunger out, re fit the switch and now the brake lights are off...
wahoo! so looks like that part is talked care of. should I put my shifter back together and it should shift now?
Old Aug 4, 2012 | 04:53 PM
A5scott's Avatar
totally fixed and back together... after i plugged the shift solenoid back in...
I fixed something!
shezm
Dec 28, 2015 11:25 PM
abran
Aug 5, 2014 06:13 PM
Rover Newbie
Jul 13, 2014 10:46 PM
AZRover
Jul 2, 2012 06:43 PM
tibyABv6
Jan 7, 2011 06:02 AM
