No Compression on left side
Good work so far.
Take some carb cleaner and try to get off all the carbon.
And, then post the cleaned up pictures.
All you will need are head gaskets hopefully.
Of course everyone will say take the head to the shop to get them checked..
I just cleaned the heads and put them back on.
But as your situation looks more severe, probably best to get your heads checked.
I had a crack in my head gasket - same place roughly.
You can't tell from the pics but there is a hole in the liner and a lot of material missing from where the hole in the liner is and the crack in the block. Also there is a chunk missing from the piston. Any how I found a used motor with 112k out of a wreck which I'll probably be picking up this week. Any tips on removing the old engine and dropping the new one in.
