No Drive!!!
Old May 2, 2013 | 08:04 AM
texgant's Avatar
Default No Drive!!!
My 02 discovery lost all drive this morning when my wife backed out of the driveway. With the park brake engaged and the truck in drive the front drive shaft is spinning freely and the rear does not move. Any ideas?
Old May 2, 2013 | 08:07 AM
OK, so you have either a broken front diff, spider gears, or a broken front CV joint.
How mechanical are you?
Old May 2, 2013 | 08:10 AM
ZGPhoto's Avatar
My front diff went this past winter, was still able to drive just made clunking sounds while turning.
Old May 2, 2013 | 08:36 AM
texgant's Avatar
I consider myself pretty mechanically inclined I do all my on work small my other trucks.
Old May 2, 2013 | 08:42 AM
texgant's Avatar
It has been making a hard clunk when backing up from a stop but never could get it to do it when I was looking for it. But shouldn't it drive with the rear or does the traction control set up not allow it?
Old May 2, 2013 | 08:43 AM
ZGPhoto's Avatar
If you had a 99-01 or 04 you could lock the centre diff, but as you have an 02 you don't have that ability.
Old May 2, 2013 | 08:53 AM
texgant's Avatar
I thought you could do it on the 02 you just had to make your own linkage to be able to shift it. I was told that and read it on here that is why I bought an 02
Old May 2, 2013 | 08:55 AM
texgant's Avatar
I do want to thank all of you are posting replies I do appreciate the help.
Old May 2, 2013 | 09:07 AM
ZGPhoto's Avatar
No you can't do that on an 02, only up to 2001.5 can you do that. 02 and 03 you need a new front output nose or a whole new T-case.
Old May 2, 2013 | 09:16 AM
texgant's Avatar
Manufacturing date is 11 of 01
