No drive help
No drive help
Hi all first post here
recently lost all drive while off road it was just after engaging the diff lock under the car for the first time ( was very stuck) felt like I was either I only getting 2wd or just lacking power but it is possible that was just in my head and it was just slipping in all the mud. Then It stoped working all together. I don’t have very long to fix it so I was just wondering if anyone knew a quick way to diagnose if it is clutch, T box or transmission. drive shafts are not spinning and I have no drive in any gears high or low.
1999 D2 manual v8
thanks
edit: forgot to mention when it first went I couldn’t get it into gear at all now it go’s in just no drive
1999 D2 manual v8
thanks
If it's a 1999 D2 then the t-case lock is a retrofit. This being the case, the linkages between the lever and the actuating pin on the transfer case might not be completely lined up. Try shifting the case from underneath the truck to be certain that it's actually engaged or disengaged.
The truck has no 2WD -- it's always 4WD.
definitely possible hopefully not as I have a spare t box lol but if that was the case I only had that lack of power feeling about 10 minutes before it went and would a clutch usually be slipping for longer before
