No Go Disco
Old Jun 17, 2015 | 09:12 AM
discobob's Avatar
Default No Go Disco
Need some help. A few weeks ago I replaced my battery. It was dead a couple of days later. So, alternator. I had it rebuilt and reinstalled it. Last evening, I went to start it, and it sounded like my starter was dragging. I figured I'd deal with it this morning, and now the truck is completely dead. Thoughts? Thanks in advance for any help.
Old Jun 17, 2015 | 09:30 AM
jamestfl's Avatar
starter wires not connected/ not connected properly. battery wires not connected / not connected properly. battery dead again?
Old Jun 17, 2015 | 09:33 AM
dusty1's Avatar
yep
i'd start by checking all connections, starting with battery/grounds/alternator
Old Jun 17, 2015 | 10:26 AM
Fast951's Avatar
Sounds like you have a larger than normal draw on the battery when the vehicle is switched off. Have you recently installed any aftermarket accessories that use power like stereo, lights, etc? If so I suggest you disconnect temporarily to see if the battery problem goes away.
