no go in drive
Old May 17, 2010 | 04:21 PM
frank418's Avatar
4wd High
Default no go in drive
pulled out of parking spot heard loud snap.car stopped going forward works fine in reverse and is able to move in 1.tried jacking each side to see if it would spin they are all solid.while driving in first and taking tight corner feels like other four whel trucksl locked in does that popping and hopping.fluid a little low am going for some now.any help would be great you guys have helped me with other problems.
Old May 17, 2010 | 04:22 PM
frank418's Avatar
4wd High
thanks for help
Old May 17, 2010 | 04:32 PM
We need to know the model and the miles on the truck.
Old May 17, 2010 | 08:19 PM
okdiscoguy's Avatar
I looked back, You have a 95 D1? Put that in your sig.
Is your t-case locked? What position is your little shifter in?
Old May 18, 2010 | 05:34 AM
frank418's Avatar
4wd High
95 disco 1 and the little handle is not hooked up its frozen i have a 157,000 or there abouts.been fixing alot of little things was hoping nothing big would go wrong but oh well. any direction would be great.
Old May 18, 2010 | 09:15 AM
You need to be more specific and write so we know what you are talking about.
Old May 18, 2010 | 10:23 AM
NiteTrain's Avatar
I think he's trying to say he's lost all gears except for 1st and reverse and it drives like the CDL is engaged.
Old May 18, 2010 | 08:29 PM
frank418's Avatar
4wd High
the noise came from what sounds like the diff area.did not know if it went up or down on the snap.and yes in low 1 it will move just fine and reverse is also okay. i have jacked upthe front end and tried to turn each wheel also in the rear they all feel solid.drive shaft front and rear also seem okay.it has been poping once and a while in the right front while taking tight turns forwards or backwards.
Old May 19, 2010 | 06:35 PM
frank418's Avatar
4wd High
okay here we go put car on stands and put in drive still no movement.just in low 1 and reverse,disconected the front drive shaft to see it binding still nothing.felt a little play in tcase decided to put drain pan underneath and pulled plug on tcase.heard and saw metal pieces hit drain pan.also had problems taking out plug due to amount of metal on magnet. now my question is do i rebuild it or replace it.and is there a certian one that fits a 95 or are they the same and is there anything else i should look at while i am in there.any info would be great.
Old May 19, 2010 | 08:01 PM
03discoman's Avatar
i'm in michigan also..
i have a extra transfer case from a 2000 disco that i can sell to you for 50$
the gear set and such is in good shape....all we need to do is swap your cdl housing.....
i can even meet you if your close!!!!
pm me your phone number and we can work something out if you'd like
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
Randy P
Sep 27, 2007 08:27 AM
05LandRover
Off Topic
Jan 16, 2006 09:49 PM
Big boy
Mar 25, 2005 10:08 PM
