No heat while idling?
When I am idling and I have my heater set on high heat it blows a slightly worm air out, but as I started to drive down the road it started to blow worm er air the faster I went the worm er it got? What you should now is this is a new disco to me with 120,000 miles the air does blow hard just not worm I looked at some fuses and could find any thing I looked to see if the heater core was disconnected and the two port that go through the heat shield are hooked up!
What should I do next?
I just replaced the three top hoses they looked a little ballooned I will get the others later but their was very little coolant in the hoses when I removed them! I was able to get a full coolant bottle in it so far and still no heat while idling!!
So I will let her cool down and I will just keep topping her off!
FYI It has never ran hot in fact it runs cooler than the 03!
It runs cooler because your t-stat is bad which means bad for the engine.
Me either because you said "Check your engine temp. If no air in coolant, replace thermostat." well sweetie I had AIR!!
No I get it spike I am from AZ if you have a bad thermostat you over heat I never thought of running cooler I guess the reason is it never fully closes! OK well I will move that back to the top of my list ARRRRR.
Thanks
Thanks
