No instrument lights!!
Old Feb 21, 2016 | 05:24 PM
CoastieDisco2's Avatar
Default No instrument lights!!
Guys good evening, I know most of you have seen this one numerous times. So please bear with me.
I checked all the grounds per RAVE. I tried a new dimmer, a new stalk, etc. I have 12V at the dimmer switch but nothing comes on.
Is it possible for the instrument board itself to go bad? My only doubt one that one is that the climate control lights went out too. All other lights internal and external throughout the car work just fine, including the glove box light.
Could someone please point me in the right direction. Also the light that shows the odometer is intermittent.
Thanks
Manny
Old Feb 21, 2016 | 06:24 PM
number9's Avatar
Sounds like a debrief from a pilot or one of my exes. Please define.
Warning lights?
Panel illumination? Mentioned speedo, fuel and temp areas of panel? AC panel out what about radio?
Switch illumination?
Old Feb 21, 2016 | 08:08 PM
The lights for the TACH, SPEEDO and other things inside the instrument panel are not working. the climate control/AC lights are working on the display but not the buttons ones.
Old Feb 21, 2016 | 08:37 PM
number9's Avatar
Switch background lights off on both sides of inst. panel bezel too?
Are you going by Rave wiring diagram? Looks as there are a couple of resistance measurements you cold take to check dimmer.
Old Feb 22, 2016 | 01:24 PM
Let me try this again, the lights which I believe there are four bulbs on the instrument panel behind the TACH, SPEEDO, FUEL and TEMP gauges are not working. They do not come on at all in any position of the light/turn signal stalk.
I have checked the grounds, new dimmer switch, new stalk. What else can I do?
Thanks
Old Feb 22, 2016 | 01:59 PM
number9's Avatar
Good question. Troubleshoot or try more parts.
File Type: pdf
Old Feb 22, 2016 | 04:06 PM
jamieb's Avatar
"new" dimmer or "another" dimmer?
Old Feb 22, 2016 | 05:43 PM
drowssap's Avatar
Have you tried checking all the fuses under the steering wheel with a test light?
Old Feb 22, 2016 | 08:19 PM
number9's Avatar
Good question.
defcrazy
Jun 24, 2018 06:51 AM
Danny Lee 97 Disco
Mar 14, 2011 03:05 PM
2002 freebie se
Freelander
Dec 26, 2009 07:01 PM
afox04
Apr 28, 2008 10:15 AM
jonnymcd
Mar 24, 2007 01:07 AM
