No Luck Here!
Welcome to the forum.
What trouble are you having?
I have not seen you post anything.
DiscoMike is retired and has health issues, he is not always available.
I have a job, kids, wife, dog...
Nobody just sits here waiting to answer questions.
Have you tried Discoweb.org? Those guys have TONS more knowledge than us.
And keep in mind if you post a question in the AM on a weekday when everyone is at work your thread is more likely to get pushed down to the next page or three.
No kidding.
My two cents, although improper bleeding can cause an air lock an some overheating they are stupid easy to bleed. If you bleed the system and it's still overheating, there is more going on here. I would check the coolant for exhaust gas, look at the plugs and make sure they look uniform and good. Are you setting of any codes? Running lean can cause an overheating issue but usually you'll get a code and the computer will try to compensate. How about your fan clutch? Losing any coolant?
