No matter what I do, the coolant level always bottoms out here…
Old Nov 17, 2021 | 12:07 PM
Brandon318's Avatar
Default No matter what I do, the coolant level always bottoms out here…
No hissing, no drama with the cooling system at all. It just always reaches some kind of equilibrium at this spot. Anything wrong with this? What explains it? If I fill it to the actual cold mark and it settles here, the extra had to have gone somewhere.
Old Nov 17, 2021 | 12:15 PM
dtmbinb's Avatar
Mark the tank with a Sharpie. If it stays there, you are fine. Each truck tends to settle at it's own location. Not a problem unless it keeps dropping.
Old Nov 17, 2021 | 01:12 PM
Richard Gallant's Avatar
You might be slightly over pressure for any of a number of non critical reasons, the excess could be going out the overflow pipe. Once it gets to the happy level it will be fine.
A catch bottle on the overflow would prove it out
Old Nov 17, 2021 | 01:26 PM
mollusc's Avatar
I had the same situation on my old truck. Changed the cap and the issue went away.
Old Nov 17, 2021 | 06:26 PM
Extinct's Avatar
Completely normal.
Old Nov 18, 2021 | 10:24 AM
DiscoveryTD5's Avatar
I experience the same level setting and have also been curious about this. It must be reservoir related because I have a TD5 engine in mine.
Old Nov 18, 2021 | 10:30 AM
Brandon318's Avatar
If @abran ever comes back out with coolant tanks, I'll take two. I regret not getting them when they were available.
oneblessedmess
Feb 16, 2017 03:34 AM
DiscoRover007
Jul 11, 2011 02:10 PM
d2luvr
Jul 21, 2009 10:37 PM
bigugly82
Aug 23, 2007 04:32 PM
bigugly82
Aug 22, 2007 08:04 AM
