No power to windows or sunroof
Old Sep 24, 2007 | 04:34 PM
Fox900's Avatar
Default No power to windows or sunroof
98 LSE Disco
My wife had a problem with the rear window. I pulled the window lift ECU and there was solder crack. Fixed eveything worked fine. While testing it a second time I blew a window fuse. Replaced the fuse and now none of the windows or the front sunroof work. Are ther other fuses or relays to check?
Old Sep 29, 2007 | 12:51 AM
johnkbl's Avatar
Default RE: No power to windows or sunroof
Voltage for window lift and sunroof is provided to the window lift ecu (Z147) from the fuses F1 and F2. The window lift ECU is grounded thorugh the c wire at ground C200....
check those fuses... hope it helps!!!
sickvehicle
Jul 16, 2010 03:44 PM
billygoat
Aug 3, 2009 10:35 PM
dmm698
Aug 28, 2007 06:37 AM
Nick C.
Feb 26, 2007 05:54 PM
sickrangerover
Feb 11, 2007 11:44 AM
