Sunroof Open rained windows wont work
Old Jul 9, 2007 | 11:31 AM
dmm698's Avatar
7th Gear
Default Sunroof Open rained windows wont work
I accidently left my sunroof open and it rained last night. The windows won't work, and the sunroof wont close, as well as the AC screen and climate controlls wont work. Anybody else have this happen? I figured i could hairdry it somewhat but dont want to start taking things apart. Any ideas?
Old Jul 10, 2007 | 06:00 AM
rodrick smith's Avatar
Default RE: Sunroof Open rained windows wont work
it happened to me just let it dry for a day in the sun and maybe everything will be alright. just figure god washed your seats for you :-)
Old Jul 10, 2007 | 10:47 AM
dmm698's Avatar
7th Gear
i took the cneter cluster out and let it dry inside over night, when i plugged it back in this morning and turn on th elights the buttons will light up, but the windows still wont move up or down. The rear window buttons in the back seat wont work either. on a good note i got the climate controll back
Old Jul 10, 2007 | 11:06 AM
that is what came back first on mine, just let it dry not that you have a choice in the matter but i bet it iwll work park it in the sun
Old Jul 17, 2007 | 07:14 AM
beer elephant's Avatar
If you took out the center cluster containing the window switches, make sure you reconnected the wires which operate those switches, in front of the passenger side of the cluster. A good cleaning of the connection to displace water should help, andensure sure no corrosion is present.
Old Aug 28, 2007 | 06:37 AM
Bleacho's Avatar
for immediately sorting it out...
Take out centre clusterstorage box & use a hair dryer all around inside it on medium heat,
aim at rear of electric window switches too.
Take a good 10-15 mins to do this.
allow to cool completely, leaving lid open.
as long as you are careful, everything should sort itself out within a few switch actions.
if sunroof is affected too, remove roof switch panel & apply heat same treatment.
if still not sorted, locate & check the relays for electric windows & electric seat controls.
check for dryness - renew fuses or dry off as necessary.
works everytime for me!
keithd21
Aug 2, 2012 07:14 PM
billygoat
Aug 3, 2009 10:35 PM
losbadgt
May 18, 2008 07:04 PM
bhorwhat
Oct 16, 2007 10:14 AM
rodrick smith
Jun 21, 2007 06:12 AM
