No spark no fuel
Do you see RPM's on the Tach when you try to start it? That could point to the CPS instantly if it isn't seeing the engine turn over, however I have had bad CPS in the past and they showed RPM's but the engine still wouldn't start. CPS is certainly a common issue especially if it's still the original one. If you get one from Auto Zone inspect it before purchase 50/50 chance it's an exact OEM Bosch unit just in a Duralast box. How did you verify no spark? Did you use a spark plug tester? CPS symptoms usually show up after the engine gets warm & it won't re-start until it cools down.
Check the fuel pressure on the rail - you can borrow a fuel pressure regulator at Oreilly. Squirt some fuel in the throttle body, see if it pops. Pull a plug wire, stick a phillips screwdriver in the plug wire and put it a short distance from grounded metal - see if a spark jumps. Swap in a CPS, Best is right they normally fail hot and will allow the engine start once cooled off.
Good luck and report back.
