No start issue - cracking n spark but alarm code?
I was doing lite work on the truck. Removed intake manifold and replaced spark plug wires, new intake gasket, valve gaskets etc. nothing major. Now it will not start. It cranks over… I have spark - also new crank position sensor installed. So I got cranking and spark it no start. I have these codes the no start. Is something with the immobilization stopping fuel or something?
Turbo Arbitrageur (05-18-2024)
spacer for the crank position sensor? I did install a quality Bosch part so. I was using my diagnostic scanner shows “key not detected”. My key broke off while back and I drilled the barrel out and been using screwdriver - which was working. I had in garage for months doing a lot of maintenance work. I also ripped my ignition apart more to stop the steering from locking. It has not started since. I am thinking it’s finally had it with my Jerry-rigged ignition. I found a used ignition w keyfab and matching door lock. Seems logical with the “anti theft codes” “no key code” and the fact chopped my ignition up pretty good? Anyways will be here in few days - hoping that solves it. I love this truck. I bought cheap and been tossing a lot coin into it to get it running well. I plan to put a suspension kit of etc and built it up. It has zero rust on it also. Great truck… just frustrating after all the work I have done not starting. So hoping for the best.
JohnZo (05-19-2024)
