No start issue - cracking n spark but alarm code?
I pulled the cover off and there are two large spacers to get the cover away from it, which I have after the sensor to space the cover away from it. Is there more spacers? Is there some other ones… I didn’t pull the sensor out yet. Was just checking it quick. But I do have two large spacers after the sensor if that is what you were talking about?
No, that won't do it. Suggest you check to make sure fuel pump is running, maybe check fuel pressure at schrader valve on manifold.
thanks…didn’t think it would cause a no start. Ordered a couple coil packs. I’ll check fuel situation also. I can smell fuel. Cracking well, I think has fuel pump is working… so guessing something wrong with the sparking?
