No tire rotation info in owners manual
thanks for the info....i am getting uneven wear on the front tires, inside left and outside right, the back tires are wearing evenly and all 4 are just over 1 year old. would a lack of rotation cause uneven wear or am i looking at possible suspension issues? i plan on doing an alignment before changing tires and then maintaining a good rotation schedule, but if i do have suspension problems would like to address that sooner than later....thanks fellas.
You have suspension issues.
Your spare will last forever if you dont rotate it into the mix.
If you do next time you need tires you will be having to buy 5 instead of 4.
So instead of spending $800 you will spend $1000.
Now lets add that if you spare is not the exact same brand/tread design of the other 4 tires you are looking at messing with the trucks stopping and handling.
