noise from Engine
Old Dec 28, 2016 | 11:11 PM
sayeedA's Avatar
Default noise from Engine
Noticed last 2 days there is this Turbine like noise coming out of Pulley/AC area. after close inspection it seem like around the AC and Pulley below it. The noise goes up as I rev the engine.
I sprayed little WD40 on the AC and the pulley below to see if anything changes, nothing. Before I took a part of the fan areas wanted to see if anyone have any opinion. Water Pump is a year old, Belt looks good
If I were to replace pulleys just to get that out of the way. what are the part numbers and where have you gotten them.
Thanks for your help in advance
Old Dec 29, 2016 | 07:14 AM
Chrisw7562's Avatar
I bought the kit from Atlantic British that also had a new tensioner on it. Not cheap but I'd read of a few tensioners snapping from age and wanted a new one. The kit made it easy for me. Land Rover Belt Tensioner Kit: Discovery 2 And Range Rover P38
There are threads on here where guys have pulled their pulley's and replaced the bearings in them for much cheaper and if I recall properly they listed some part numbers for the bearings. Just do a search.
Old Dec 29, 2016 | 07:17 AM
coors's Avatar
Pull the serpentine belt off and check each pulley individually.
First: Spin them, do they all spin freely? If so, move on. Check each one for bearing play can you move the pulley side to side or up and down?
Pay close attention to the power steering pulley - they have a tendency to fail quite often. The pulley / shaft will walk out of the pump housing putting undue pressure on the bearing causing it to whine.
Old Dec 29, 2016 | 09:22 AM
sayeedA's Avatar
After reading my own late night post I have hard time understanding what i was saying - LOL
Thank you for the advice. I read many places about the Power Steering pulley issues.
Let me pull everything out and see where is the problem as Coors suggested. but sound definitely coming from the Driver side.
Old Dec 29, 2016 | 09:32 AM
LR03NJ's Avatar
I would like to say, if you are to change the pulleys, one is 80mm. Just in case you might order the same size like what I did. cheers!
Old Dec 29, 2016 | 02:19 PM
sayeedA's Avatar
Default Discovery Whining noise
I did some initial observation and made small video just to see if anyone can recognize this noise.
I was thinking the Power steering but seem like coming directly below the AC compressor.
I am hoping its the upper Pulley.
Old Dec 29, 2016 | 02:48 PM
OffroadFrance's Avatar
It sounds like a dry bearing moaning Sayeed and hopefully an idler gear and not the A/C compressor or PAS pump. As Coors states, pull the serpentine belt and check each pulley for wear, play and noise.
Old Dec 29, 2016 | 03:18 PM
sayeedA's Avatar
I am hoping the same. I have been doing some research on the PAS. I don't think its AC. As I sprayed sine WD40 on that because it was easier to get to that did not see any changes.
Regardless, I have to replace my valve cover gasket (I screwed up last time) so As I go in I will start checking them all. They are all original so may be time to replace both the 80mm and 70mm.
Anyone has a good source to buy besides BA?
Thanks
Old Dec 29, 2016 | 06:51 PM
Charlie_V's Avatar
Thanks
I responded on a different thread and my best guess is a bearing. I just received the 80 and 70 pulleys. I bought them from AB but the purchase was on eBay. One of the pulleys (can't remember which) is commonly available at auto parts stores for cheap.
Old Dec 29, 2016 | 06:53 PM
Charlie_V's Avatar
I was wrong. They are from British Pacific.
Aw geez. Closer inspection reveals that IS Atlantic British.
