noise from Engine
noise from Engine
Noticed last 2 days there is this Turbine like noise coming out of Pulley/AC area. after close inspection it seem like around the AC and Pulley below it. The noise goes up as I rev the engine.
I sprayed little WD40 on the AC and the pulley below to see if anything changes, nothing. Before I took a part of the fan areas wanted to see if anyone have any opinion. Water Pump is a year old, Belt looks good
If I were to replace pulleys just to get that out of the way. what are the part numbers and where have you gotten them.
Thanks for your help in advance
I bought the kit from Atlantic British that also had a new tensioner on it. Not cheap but I'd read of a few tensioners snapping from age and wanted a new one. The kit made it easy for me. Land Rover Belt Tensioner Kit: Discovery 2 And Range Rover P38
There are threads on here where guys have pulled their pulley's and replaced the bearings in them for much cheaper and if I recall properly they listed some part numbers for the bearings. Just do a search.
Pull the serpentine belt off and check each pulley individually.
First: Spin them, do they all spin freely? If so, move on. Check each one for bearing play can you move the pulley side to side or up and down?
Pay close attention to the power steering pulley - they have a tendency to fail quite often. The pulley / shaft will walk out of the pump housing putting undue pressure on the bearing causing it to whine.
After reading my own late night post I have hard time understanding what i was saying - LOL
Thank you for the advice. I read many places about the Power Steering pulley issues.
Let me pull everything out and see where is the problem as Coors suggested. but sound definitely coming from the Driver side.
Regardless, I have to replace my valve cover gasket (I screwed up last time) so As I go in I will start checking them all. They are all original so may be time to replace both the 80mm and 70mm.
Anyone has a good source to buy besides BA?
Thanks
I am hoping the same. I have been doing some research on the PAS. I don't think its AC. As I sprayed sine WD40 on that because it was easier to get to that did not see any changes.
Thanks
Thanks
I responded on a different thread and my best guess is a bearing. I just received the 80 and 70 pulleys. I bought them from AB but the purchase was on eBay. One of the pulleys (can't remember which) is commonly available at auto parts stores for cheap.
