noise from Engine
#51
80mm Bearing fix
Parts: NTN 6304LLU - Found this from an Australian site
6304 CLOSURE TYPE: 2RS Both Sides Rubber Sealed, from From Autozone.
The clip was hard to get out. Spray some PB Blast to loosen use a strong needle nose pliers and screw driver to pop out. Clean and use the same AC bearing process.
Now I have all metal pulleys. I will have to finish the Valve cover before i complete the Pulley areas. I dont want stuff flying around and get inside Intake or valve. Most likely I will clean the whole AC, Alternator area.
Hope this helps someone
JUKE179r (01-08-2017)
#52
I know someone asked to put some pic.
Parts - AC Compressor Clutch Bearing NACHI # 30BG05S2G-2DS (30mm ID x 52mm OD x 22mm) cross reference Santech Industries MT2027 Double Row Air Conditioner Bearing 30mm x 52mm x 22mm
I thought it was easy to take out the Bearing and replacement. there was one Clip holding the Bearing assembly.
I used 30 MM Socket to hammer the bearing out. pressed and hammered back with the old bearing. see the pic
#53
you are welcome. after examining all the parts. the original Metal bearing 80 and 70mm i would keep the old pulleys and just change the bearing. aftermarket aren't as heavy.
the Gate tensioner metal pulls is damn solid
#54
#55
Sayeed - the alum parts look exactly how I'm hoping to get mine. What kind of paint did you use? Thanks...
#57
Valve cover Gasket I used high temp Red Rust-oleum with paint brush much thicker coats. I had all the paint in my garage so just used them.
Hope that helps.
#58
I got all the parts i needed - love the mouse click shopping.
DAYCO 89052 Idler Pulley (Small idler) lighter than original - $ 11.09 (Rock Auto)
GATES 36102 Tensioner Pulley (looks very strong better that original plastic $ 12.81 (Rock Auto)
NTN Bearing 6304LLU for the Large Idler need assembly from Amazon - $20
Continental Elite 4070923 Serpentine Belt $30 (including shipping and Tax) – I had Dayco belt piece of junk.
AC Bearing - Santech Industries MT2027 30mm x 52mm x 22mm (Cross reference with original NACHI # 30BG05S2G-2DS) got this at Autozone for $17
Since i was waiting decided to tackle the Valve cover gasket as well. I am going to get rid of those hideous bolts. Some braindead engineer decided to put those little bolts compare to the weight of the cover. they should have 3 bolts on each side and larger. I am going to replace them with 11mm head and 6 corner. see the pic. will be using a lot of Locktile they were loose when i pulled them out. also some permatex copper spray gasket on both side.
Now the real work starts but it's freaking cold out.
