Non ACE BCU
Old Feb 24, 2025 | 07:33 AM
ericg's Avatar
Default Non ACE BCU
I've got an 02 that I removed the ACE from, I've got a non ACE BCU does it need to be reprogrammed to use it to use in the truck?
Old Feb 24, 2025 | 08:16 AM
Extinct's Avatar
You would need to have it programmed for it to work with your current ecu, or you need the matching ECU.
Old Feb 24, 2025 | 09:29 AM
ericg's Avatar
I just happen to have the ECU as well
Old Feb 24, 2025 | 09:31 AM
sqlbullet's Avatar
Yes it does.
Old Feb 25, 2025 | 04:39 PM
99TEXASD2's Avatar
if you have the ECU and BCU you should be fine....worst case scenario you need a nanocom (or someone with one) to re-sync the ECU/BCU (yes even if they have same vin they can lose this), but it doesn't happen very often. I think the only thing you might end up with by swapping is your speedometer might flash at you...again a nanocom can fix this.
ericjlamyot
May 6, 2020 05:25 PM
cornercase
May 24, 2013 11:43 AM
earlyrover
Apr 30, 2013 03:33 PM
jycsalas
Dec 17, 2008 11:00 AM
alrd
Nov 17, 2006 11:25 AM
