Non-ACE combined PS reservoir?
Old Mar 26, 2020 | 08:42 PM
DiscoJax's Avatar
Default Non-ACE combined PS reservoir?
Has anyone found a way to perforate the partition in the non-ACE power steering reservoir in order to make use of the fluid that sits unused? One could theoretically double the volume of fluid available.
Old Mar 27, 2020 | 06:17 AM
XRAD's Avatar
You mean perforate the dual chamber reservoir 'W/ACE'? Just use a hot bent metal rod and melt a few holes through bottom of partition, or get a cheap used Non ACE reservoir(if you have ACE torsion bars removed).....
You are only doubling the volume if you have ACE disabled, otherwise you are just sharing the volume, and if one side hose fails, then you lose both volumes
Old Mar 27, 2020 | 06:54 AM
mollusc's Avatar
The non-ACE reservoir doesn't have any internal partition. There's no "unused" fluid in it.
Old Mar 27, 2020 | 08:59 PM
greisinb's Avatar
There is a partition, but it’s more of a baffle I guess, Fluid can move around from one side to the other but pumping it all out for a fluid changeout can be a little tough.
Old Mar 28, 2020 | 07:48 PM
DiscoJax's Avatar
Exactly. The baffle goes about 2/3 of the way up so there isn't really much circulation there. I like the idea of a hot bent rod. A hole or 2 at the bottom of the baffle should do the trick. Thanks.
calebbo
Mar 28, 2021 12:13 PM
RHD 4 LIFE
Dec 1, 2012 05:48 PM
Jabez
Feb 6, 2012 02:56 PM
RedAustinIX
May 25, 2011 02:20 PM
jrkstore43
Jun 17, 2009 12:40 PM
