non start
Old Apr 17, 2014 | 07:09 AM
kris83a's Avatar
6th Gear
Default non start discovery 2
Hi anyone know why my disco 2 cut out and wont start.. not crank sensor or fuel problem as all been checked.. turns over but wont fire unless easy start is used then just cuts out again any help would be great thanks
Old Apr 17, 2014 | 08:12 AM
Joker86's Avatar
What you stated sounds like a fuel delivery problem.
Old Apr 17, 2014 | 08:15 AM
kris83a's Avatar
6th Gear
Yeah I know but cant find a problem as pump works and got new filter,all injectors work and fuel lines all clear.. also no faults on computer also has brand new glow plugs and recent service
Old Apr 17, 2014 | 08:24 AM
Joker86's Avatar
Well, what about compression?
Old Apr 17, 2014 | 10:11 AM
dusty1's Avatar
shrader valve on fuel rail will give you psi with a standard tire pressure gauge.
you haven't triggered the inertia switch,have you?
Old Apr 17, 2014 | 10:22 AM
kris83a's Avatar
6th Gear
Shrader valve ? And where would I find the inertia switch.... was just driving normal when it cut out and its never worked since
Old Apr 17, 2014 | 10:23 AM
Joker86's Avatar
Ohhh good call..... Forgot about that one.
Old Apr 17, 2014 | 01:00 PM
dr. mordo's Avatar
...brand new glow plugs...
Glow plugs or spark plugs? It is a diesel? Serious question, btw, not being a jerk about terminology.
One problem that is sometimes misdiagnosed as the crank pos sensor is the fuel pump relay. It's under the hood in the relay box by the battery. Just swap it with the windshield washer relay next to it and see if it starts.
Old Apr 17, 2014 | 01:06 PM
dusty1's Avatar
inertia switch = on firewall at passenger side . about 3" tall w/ a big black rubber push button on top
fuel rail is under upper manifold. valve is like the one on your tire. it's poking out of the back
Old Apr 17, 2014 | 02:35 PM
kris83a's Avatar
6th Gear
its a td5 51 reg thats the most info given so far thanks will have a go in the morn when garage is open thanks
