Normal Operating Temps w/a 180F thermostat
Old May 16, 2013 | 11:41 AM
Dan7's Avatar
Sound advice, but it is working. Can't verify that it's opening at exactly 180F, but it is opening. My guess is some other aspect (likely the radiator) isn't at 100%. Going to flush, then retest.
Old May 16, 2013 | 12:28 PM
Mojigglins's Avatar
how many mile on your truck? you might be wasting your time trying to flush the rad, I flushed mine three times at home and even took it to a shop to flush but no change at all in temps, after driving around for a bit feel the rad top to bottom there should only be about a 10-20 degree diff from top to bottom, is you bottom rad hose colder than the top?
Old May 16, 2013 | 01:55 PM
slabrat's Avatar
I have a 180 Motorad in the 99 and the temps are 195 - 197 Might get to 201 in stop n go traffic, I suppose my radiator is a bit plugged since it has 220k on it. Putting one in the 04 soon It runs a bit hot getting up to 205 at times so I am anxious to see how much the 180 drops it.
Old May 16, 2013 | 02:27 PM
AdrenalinPlease's Avatar
Originally Posted by Mojigglins
I just replaced my rad and put in a 180* t-stat and I run 194-197 on the hwy and 199-201 stop and go or climbing up long steep hills. before I was running 215-220 all the time. how is you fan clutch and water pump? how many miles on you truck? rad could be a bit clogged
Me also same.
Old May 17, 2013 | 07:13 AM
drowssap's Avatar
Dan7,
aren't you running a new block? your temps will be higher.
Old May 17, 2013 | 06:02 PM
pinkytoe69's Avatar
With 75 miles on a new radiator, fan clutch and motorad 180 I have these exact temps with an occasional random spike to 203. I havent done the front shaft yet, so I have not gone highway much at all.
Sounds like the grey diesel OEM stat runs cooler.
Old May 17, 2013 | 06:19 PM
caymandrew's Avatar
Unless I have an anomaly I would say yes. I just did a three hour drive today and did not break 183.6* while cruising at 65-70MPH. I did see 190.4* sitting at a light for what seemed like forever, but that was the highest I've seen since installing the OEM grey warm climate t-stat.
Old May 17, 2013 | 07:01 PM
pinkytoe69's Avatar
I don't think its an anomaly. I'm pretty sure I've read other posts thatvsay the grey sits in the 180s
Old May 17, 2013 | 10:01 PM
redwhitekat's Avatar
I run 195-201 in the winter and now it's about 20 Celsius and still same temps
Old May 17, 2013 | 10:23 PM
Mojigglins's Avatar
Maybe we should all just do this?
