Not your typical CDL question..
I have a 2000 DII. From everything I have read online it should have a CDL, just no shifter for the CDL. No where can I find that 00's did not have a CDL. From 99-02 and 04 it looks like they all had them, with or without shifter.
When trying to find the "nipple/bolt/spigot" (whatever you call it in your country) to turn the CDL on from underneath the truck (on the top near the front driveshaft attachment) my hands are finding blankness, wide open spaces of nothing. So I decided to get a light and video recorder up in the spot.
This is what I found. Nothing. Am I looking in the right place?
Any and all guidance is much appreciated. Thanks
I have the Hi/Lo, just not the Diff on the Shift, which I thought was typical of the 2000. Figured I at least had a 2000 TC but your answer confirms my worst fear. Reason it is my worst fear is that I have taken out the front shaft to replace u's and yoke but having a hard time sourcing the middle yoke between the two u's on the back of the front shaft. Thought I would engage the CDL and drive on, but currently when just trying to drive it up and off of ramps to work on it the rear end and TC are making horrible noises and grinds and bangs and such, thought maybe the TC was in a "half" CDL lock position. Yet there is no position cause there is no switch.
So if there is no switch for CDL, and there is no front driveshaft right now, how is any power going to the rear at all? Cause I can still drive it a few feet it just makes noises like its trying to drag me to hell with it.
Where are the noises coming from? The TC noises may just be the ABS pump and calipers trying to reconcile the lack of a front shaft. Is this 4 high or low?
On the CDL itself, my ‘00 has a light that comes on in the dash when I engage it and I didn’t wire anything. I used a unit from an ‘04.
