CDL question
Old Dec 10, 2006 | 01:37 AM
Willie 00D2's Avatar
Default CDL question
I am making a CDL linkage assembly. Today I put the lever on the tranfercase and it easily engages/disengages the CDL. After the test around the yard I disengaged the CDL with no problem. The ABS light And the TC light came on until I turned the engine off and restarted it then they went off. The Red CDL light is on when the CDL is engaged. After disengaging the CDL the red CDl light stayed on until I moved the vehical about a hundred feet. Is there something wrong? It still drives on the street normal.
Thank you,
Willie
Here is a link to the CDL linkage;
http://www.rovershoppe.com/cdl_handle.html
And a nice modified 2001 Discovery with this CDL linkage;
http://www.cardomain.com/ride/707844
Old Dec 10, 2006 | 11:42 AM
Default RE: CDL question
Everything it is doing is normal, the trio of lights will come on when you engage the CDL, they will stay on till you disengage the CDL and restart the engine. Once ia awhile the CDL light will stay on till the truck is moved so it can dieengage the gears inside the t/case.
Now go out on a trail and see the difference it makes.
mike
Old Dec 24, 2006 | 02:17 AM
Thank you for your help mike. I Installed the CDL linkage today. It locks the transfer case easily. Not as nice as the factory version but $700 dollers cheaper. I tested the rig on a steep hill climb. Without the transfer case locked the traction control was on all the way to the top, a lot of throttle was needed and wear to the brakes. With the CDL locked the traction contol never came on and never spun a tire. This is definitly the best modification for offroading.
Willie
Old Dec 24, 2006 | 10:45 AM
Glad it worked well for you, your are right, cheap traction.
Mike
Old Jan 19, 2007 | 11:59 AM
acgmarketing's Avatar
Hi - do you have pictures / plans for the linkage?
Old Jan 19, 2007 | 07:05 PM
This is where I found it http://www.rovershoppe.com/cdl_handle.html
Willie
Old Sep 10, 2008 | 03:28 PM
NiteTrain's Avatar
will a D1 CDL shifter work on a '99 DII? I called roverland parts and they told me I need the '04 shifter that cost $329.
Old Sep 10, 2008 | 04:23 PM
Disco2Guy's Avatar
Yes the D1 linkage will work, but you'll need to bend one of the pieces. Here's one of two write-ups on installing the D1 linkage.
Old Sep 11, 2008 | 01:58 AM
NiteTrain's Avatar
Has anybody tried using an electric solenoid to turn the CDL stud? I know some people complain about them sticking and hard to turn after years of non-use but mine turned really easy.
Old Sep 11, 2008 | 02:05 AM
Urban Panzer's Avatar
Several companies make Solenoid versions of the CDL lever, the only "bad" things I have heard is they can pack up after a year or so due to lots of water and mud "if" you wade a lot etc.
turbodave
Mar 29, 2019 07:22 AM
BrandonS
Jan 6, 2015 09:30 AM
lipadj46
Feb 11, 2010 07:45 AM
discotx
Dec 11, 2007 09:50 AM
Disco Alan
Jul 11, 2006 06:33 PM
