Now I've really gone and done it - help
Ok, after a successful day of finally getting my viscous fan clutch off (with bloody knuckles to show for it) I tore everything apart according to the RAVE for a power steering pump replacement. I started putting everything together and followed (or so I thought) the torque specifications and broke the two bolts holding the PAS pump into the auxiliary housing and stretched the long bolt in the block that goes through the auxiliary housing and the top-middle hole of the PAS pump. I don't know if I read my torque wrench wrong (most likely) or it's way off calibration but it's a moot point at this moment. The damage is done. I'm going to need two new long bolts and the really long one coming out of the block. Where do I get them? Not the least of my worries is the fact that I still have two bolt ends still stuck in the auxiliary housing for the PAS pump. How does one get them out?
Wow bro, bad day..... yikes..... I will send the bolts next day to you if you want & as far as the broken bolts you need to drill a hole up the center of them soak them in pb blaster for a bit and then you run as large of a self tapping screw as possible in the hole Before running the self tapper in heavily coat the treads with jb weld and let that stuff set up. Good luck and let me know about the bolts?
Thanks Savannah Buzz for the suggestion, I found a fastenal store just a few miles from home. I'll be there bright and early tomorrow, part in hand to see what tools may help.
I attached the same photos with drawings to emphasize the problem points.
Time for a strong drink.
Funny you should mention that as I almost always go by feel. For some reason, I got it in my head to follow the rules today and torque things properly..... I agree with the head bolt comment. Thanks everyone for the comments and help! I'm off to fastenal tomorrow morning.
