Now that I've trashed the engine . . .
Old Feb 10, 2020 | 02:01 PM
  #41
zski128's Avatar
This is the block with the cracked sleeve from being hydro locked, correct? If It’s still in the vehicle I would remove the engine and pressure test it on a table or floor. You can then heat the block using some kerosene heaters or even put it on an old BBQ on low. I still would not use that block. I would be afraid that the cracked sleeve pieces would eventually fall into the engine. I also bet that that cylinder bore is out of round now as well.
MKARL
Jan 15, 2014 08:07 PM
acamato
Jun 8, 2013 04:09 PM
Satisfying Pie
Jan 8, 2011 11:24 PM
tweakrover
Jul 3, 2009 04:37 PM
zerochills
Jan 21, 2008 08:42 AM
