Is Now the Time to Trade it In
Old Sep 11, 2007 | 08:26 AM
pfselby's Avatar
4th Gear
Default Is Now the Time to Trade it In
I was driving my Discovery SE7 down the highway on Thursday and the engine just stopped. I pulled the car over, called AAA and after waiting 30 minutes the car started again. I drove it off the highway and it stopped in the middle of a busy intersection. Some merciful soul pushed me to a gas station and again, 30 minutes later it started. Took it to my mechanic who says it a fuel pump and crank sensor. It is a 2001 with 130,000 miles and I just paid $4000 for 120,000 mile maintanence. Additionally, I recently hit a fire hydrant that suddenly sprotted legs and ran into the middle of the street causing $9000 in damage (insurance company probably should have totaled it).
I am wondering if I should continue to sink money into this car or if I should decide it is the begining of the end and trade it in. I know its somewhat of a crap shoot, but would be interested in hearing what everyone has to say.
Old Sep 11, 2007 | 09:39 AM
okdiscoguy's Avatar
Default RE: Is Now the Time to Trade it In
Depends on what you want. If you like it, keep it. You have paid for major services, and you know your truck. I know that even if I had to replace the motor, I would keep my Discovery. I love it.
Old Sep 11, 2007 | 09:48 AM
How could you have spent $4000 on a 120K service? Worst case the service would cost you no more then $1000 to $1200 if they really replaced all that should be done.
As for what is going on now, exactly what fault codes do you have?
Old Sep 11, 2007 | 10:12 AM
pfselby's Avatar
4th Gear
Fuel pump and crank sensor.
Mike, it appears there was much to be done on Sally (my 2001 Disco SE7). The repairs were as follows:
COMPLAINT: ABS, TC & HDC Lights are on[/b]
CAUSE: 1. RHR ABS Wheel Speed Sensor faulty[/b]
2. FRT & Rear Brake pads & rotors worn below specs[/b]
CORRECTION: Replace RHR wheel speed sensor and FRT & Rear brakes pads & rotors[/b]
PARTS: Wheel Sp Sensor
LABOR: Wheel Sp Sensor
PARTS: Brakes & Rotors
LABOR: Brakes & Rotors
COMPLAINT: LHF Turn Lamp cracked; water ingress[/b]
CAUSE: Same[/b]
CORRECTION: Replace Lamp Assy[/b]
PART:
LABOR:
COMPLAINT: Horn comes on at random
CAUSE: Steering wheel switch came apart
CORRECTION:
So, that in combination with standard service, costs that much. And that was done through a Rover mechanic who had his own shop. Land Rover Service wanted $6000.
Old Sep 11, 2007 | 10:13 AM
pfselby's Avatar
4th Gear
Oh, I forgot this.
******NEEDED REPAIRS OBSERVED DURING INSPECTIONS OF VEHICLE******
1. Intake manifold and throttle body heater leading coolant; need to replace gaskets
2. Front timing cover leaking oil. Need to replace seals.
*******RECOMMENDED PREVENTATIVE MAINTENANCE
1. Replace all coolant hoses
2. 120,000 miles services, air induction cleaning, fuel rail, and injector cleaning, power coolant flush
Old Sep 11, 2007 | 10:24 AM
98roverguy's Avatar
If you named your rover you shouldn't get rid of it.
Old Sep 11, 2007 | 11:00 AM
okdiscoguy's Avatar
X2 on that. You have already got most of it done. Drop a few more and enjoy. If you sell now, you will lose more than you will spend. With gas prices so high, these things are getting cheaper and cheaper.
Don't break Sally's heart.....
Old Sep 11, 2007 | 12:34 PM
Before you do any work on your truck in the future, check with us and see if the estimate is right, we will probably save you a bundle.
Take care,
discoland
Sep 6, 2023 01:42 AM
Bowesmobile
May 24, 2011 09:36 PM
Roca316
Mar 17, 2008 10:33 AM
Skibum232
Nov 20, 2007 05:46 PM
larsenken
Sep 7, 2007 08:19 PM
