Now the vibration
Old Aug 3, 2012 | 04:03 PM
PAPAGALLO's Avatar
4th Gear
Default Now the vibration
Hello guys
hope all is well!my 2004 disco has been great to me up to the 56000 miles it has.there was a little vibration so i decided to check u joints and they were bad.now after changing the front drive i notice a heavier vibration at around 30-50 mph.what do you think this can be? Mecahnic says rear u joints were fine just did the front.any input is greatly apreciated.thank you.
Old Aug 3, 2012 | 04:06 PM
DiscoRover007's Avatar
When was the last time you got an alignment? Tires balanced and rotated?
It's possible that the drive shaft wasn't put back the way it was originally oriented. I've heard of guys having vibration because of that so when I had mine rebuilt I marked mine with a silver sharpie on both sides of where the shaft attaches to. This might not be true but I did it to make sure to avoid problems.
EDIT: Also check for balance
Old Aug 3, 2012 | 04:19 PM
PAPAGALLO's Avatar
4th Gear
If this is so how can it be oriented in the correct way?thank you for your quick response.
Old Aug 3, 2012 | 07:37 PM
A5scott's Avatar
also, a slim possibility that your new driveshaft is not properly balanced. this is what I'm dealing with, but it's an easy fix. where did you buy your replacement?
Old Aug 4, 2012 | 05:53 PM
whiski runner's Avatar
4th Gear
I too am having the same trouble so I've decided to take both front & rear shafts out and have them balanced. My vibration doesn't start till I hit 55-60 on up.
Old Aug 4, 2012 | 10:58 PM
lr2001silver's Avatar
Banned
Also agree that the drive shaft may not be balanced correctly. That will cause a viberation and a worn tire or a bent rim could be to blame.
Old Aug 5, 2012 | 07:55 AM
Did you have the drive shaft rebuilt or replaced with a new one? If rebuilt, did your mechanic replace the centering ball, if not, that will be your problem.
Did your mechanic grease all the u joints when installing them?
For a simple test, remove the front drive shaft, shift into high lock and drive on the rear shaft only, is the vibration gone, if so bad rebuild.
Old Jan 23, 2017 | 06:23 AM
dwatterson1's Avatar
my 2003 disco II experienced the vibration problem , it felt like I was driving on a very rough road . I stopped the truck and checked the tires , all were ok .I started back up and the vibration had stopped . Any ideas ? It then showed a code that I haven't checked yet , I will do so today .
steveo2000
Oct 30, 2024 08:31 AM
uoflcardfan77
Aug 6, 2015 03:47 PM
97discofl
Dec 2, 2010 09:25 PM
Disco Fuego
Mar 4, 2009 04:04 PM
Benhamtroll
Dec 13, 2004 04:35 PM
