the numbering of the injectors/cylinders on the TD5 engine
Hello,
Need your advice,
which is injector/cylinder number 1 on the TD5 engine?
which side does it start from? from the timing chain or from behind?
from a red arrow or from yellow as I marked on the picture
need in order to code injectors to the ECU
as I know, injector number 1 is nearest to the timing chain, the red arrow on the picture, please confirm if I'm correct.
Regards
David
Need your advice,
Regards
David
davidgugava (09-21-2020)
Thank you,
I knew this, but I wanted to make sure
No, unfortunately, I don't have Nanocom, I need to rent or find a service.
One person has a car diagnostics service and can code injectors for ECU, but the program is currently out of date and will get it in October.
If I drive a car without decoding until October, will it hurt anything?
