the numbering of the injectors/cylinders on the TD5 engine
Old Sep 20, 2020 | 02:48 PM
davidgugava's Avatar
5th Gear
Default the numbering of the injectors/cylinders on the TD5 engine
Hello,
Need your advice,
which is injector/cylinder number 1 on the TD5 engine?
which side does it start from? from the timing chain or from behind?
from a red arrow or from yellow as I marked on the picture
need in order to code injectors to the ECU
as I know, injector number 1 is nearest to the timing chain, the red arrow on the picture, please confirm if I'm correct.
Regards
David
Old Sep 21, 2020 | 03:53 AM
JUKE179r's Avatar
Hey David.
Cylinder arrangement... No. 1 cylinder at front of engine and that goes for the injector also. Your yellow arrow is pointing to the 5th injector/cylinder.
Firing order 1 - 2 - 4 - 5 - 3
Do you have a Nanocom to code the injectors?
Old Sep 21, 2020 | 06:40 AM
5th Gear
Thank you,
I knew this, but I wanted to make sure
No, unfortunately, I don't have Nanocom, I need to rent or find a service.
One person has a car diagnostics service and can code injectors for ECU, but the program is currently out of date and will get it in October.
If I drive a car without decoding until October, will it hurt anything?
DiscoTime
Sep 17, 2019 08:35 PM
stratford4528
Jul 26, 2015 03:09 PM
coldstart
Mar 18, 2015 03:55 PM
Willem Swan
Jun 27, 2012 10:44 AM
discoper
Mar 20, 2008 09:22 AM
