O2 male connector on wiring harness, where to find new
Old Nov 25, 2022 | 11:33 PM
Frank4's Avatar
Default O2 male connector on wiring harness, where to find new
Can anyone point my in the direction of one of these. The drivers pre cat male connector on the wiring harness is pretty badly corroded and I am having trouble finding a new replacement connector.
many thanks
Old Nov 26, 2022 | 07:43 AM
mln01's Avatar
I expect your best opportunity is to find one from a truck that's being parted out, with bonus points for a parts truck where the engine has been removed giving easy access to cut the connector from the harness with a long pigtail. My first thought is to try Will Tillery.
Old Nov 26, 2022 | 08:15 AM
Alex_M's Avatar
If I recall correctly, and I very well may not, but I seem to remember fronts and rears have inverse connectors. If that's true you could take the plug off of an old o2 sensor and graft it back into the harness.
Old Nov 26, 2022 | 10:43 AM
RA122125's Avatar
Banned
Here is the cheapest and easiest product I found to replace a damaged O2s connector, works for either front or rear sensors. They are an identical match to our D2's, and makes it easy to extend the wiring.
Amazon Amazon
Old Nov 26, 2022 | 02:01 PM
sqlbullet's Avatar
Originally Posted by Mntnceguy
Here is the cheapest and easiest product I found to replace a damaged O2s connector, works for either front or rear sensors. They are an identical match to our D2's, and makes it easy to extend the wiring. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This is your huckleberry. I used these when patching mine back together.
Old Nov 26, 2022 | 06:55 PM
Frank4's Avatar
I saw that on Amazon and hesitated because I wanted to find the actual connector. Looks like the Amazon part is the way to go, just ordered.
Old Nov 27, 2022 | 08:01 AM
mln01's Avatar
I'd forgotten about those. But if the old connector is corroded you'll still be cutting and splicing, right? at least you'll end up with a lot longer harness-side cable. Be sure to zip tie the longer cabling away from the exhaust manifold.
Old Nov 28, 2022 | 11:33 AM
Frank4's Avatar
Would be cutting but not splicing. Trimming the ends of the wires and assembling a new connector at the terminal end. Doing this would be my first choice if new connectors were out there.
Old Nov 30, 2022 | 12:08 AM
Discorama's Avatar
Part-No
Sumitomo 6181-0073 (male)
Sumitomo 6189-0132 (female)
Datasheet: https://prd.sws.co.jp/components/series/pdf/en/hws.pdf
On ebay:
https://www.ebay.com/itm/134050282585
https://www.ebay.com/itm/254655731625
Amazon:
Amazon Amazon
Other sources:
https://www.automotiveconnectors.com/4-way-sumitomo-hw-series-connector-grey-male.html
https://octopart.com/6181-0073-sumitomo+electric-59339395
Old Nov 30, 2022 | 11:30 AM
Frank4's Avatar
Discorama, many thanks. Just ordered.
