o2 sensor "no connectivity"
Old Jul 9, 2007 | 05:38 PM
scottagnew101's Avatar
Default o2 sensor "no connectivity"
My Bank 2 Sensor 2 o2 sensor was throwing this code so i cleaned it (the connectors). And the CEL stayed. Got a new o2 sensor and plugged it in and it still wont go away, after a good 10+ start up's and clearing it at autozone. What should i check now. Obviously it must be something to do with the wireing but i dont know where to start. Thanks for any help,
Scott
Old Jul 10, 2007 | 07:47 AM
Default RE: o2 sensor "no connectivity"
How many miles on your truck?
I believe that there were some wire harness issues releated to the 02 harness you might want to look into that.
Mike
Old Jul 10, 2007 | 08:15 AM
Hey mike,
My truck is a 2000 with around 93,000 miles. thinking back on it, it might be no activity. not real sure. I think when i get a chance i might disconnect all of them then re-connect, maybe its just getting the o2 signal mixed up? Any other information you can give me about the wire harness issue would be great. Thanks mike,
Scott
Old Jul 10, 2007 | 04:35 PM
May want to call a dealer and see if there are any TSB's on this problem.
Mike
Old Jul 10, 2007 | 11:39 PM
erick from brighton's Avatar
Hi! My name is erick and I am new at this forum thing. I am totally confused on how to post a question and how to get this "Fast Reply" off. I clicked on it thinking I could click it off or cancel it. Unfortunately, there's not a cancel bottom. So I decided to use it and hopefully you or some one else can help me with this two problems; posting a question and cancelling or turning off the screen for "Fast Reply". I am so sorry but instead of helping you I am asking for help from you.
Old Jul 12, 2007 | 05:17 PM
Rondo's Avatar
Sounds like you may have some damage to the harness somewhere upstream of the sensor. Chase it down with a light tester or multimeter.
Old Jul 12, 2007 | 06:35 PM
Thanks for the info, i am planning on testing the connection tonight. My only problem is i know how to test the connector thats at the o2 side, but where do i go from there?
Old Jul 12, 2007 | 07:02 PM
EVN137's Avatar
scottagnew101
I changed my O2 sensors (all four of them). I got (no activity) code on one sensor because the connection was not good. I know its in a hard to get place specially the bank 1 sensor 1. Make sure the connectors "click".
Ed
2000 LR Discovery II ( 99000 miles )
Old Jul 13, 2007 | 08:09 AM
EVN137, thanks for your reply. Im getting the code on my bank 2 sensor 2, however i have replaced it. What are the odds that it would somehow get the signal mixed and its actually not the bank 2 sensor 2, but actually another sensor? When i get some free time im going to un-plug them ALL, and re-connect. Thanks again for all the help.
Scott
Old Jul 13, 2007 | 09:59 PM
EVN137's Avatar
Scottagnew101
Not a chance, and never heard of the signal crossing over. Those are very specific. With the left O2 precatalyst sensor connector, if you can't get you hand in there to make the connection, like me, just allign it first then use a dowel to push the connectors together. You will hear and feel it "click". The rest of the 02 sensor connectors are pretty benign compared to the one I just mentioned.
Ed
Griz
Oct 15, 2010 07:41 PM
djmalachi
Jun 18, 2009 11:56 PM
geonuine
Feb 2, 2009 10:47 AM
LR2shortsguy
LR2
Jun 15, 2008 10:01 PM
fanatic516
Oct 29, 2007 09:44 PM
