O2 sensor
Old May 6, 2007 | 11:42 PM
robdis96's Avatar
Default O2 sensor
anyone know of a good place to get O2 sensor for a good price, did a quick search and found nothing to impressive. Usually use AB $69.
(just got a P0150 code, RH front)
Thanks
Old May 6, 2007 | 11:49 PM
Default RE: O2 sensor
Mid $65 range is about as good as it gets. How many miles on your truck?
Mike
Old May 7, 2007 | 01:50 PM
robdis96's Avatar
Thanks, right now I'm at 92K
Old May 7, 2007 | 02:29 PM
You should change out all four O2's at the same time if you want to regain some lost power and milege. If you are looking for a bandaid amke sure that you use the same make O2 as you replace them one at a time. At the 100,000 mile mark they should all be replaced.
Mike
Old May 7, 2007 | 04:30 PM
Landzu's Avatar
Just saw that you have a Disco II I dont know a thing about them.
Had put up what was needed for the Disco I
Old May 7, 2007 | 06:25 PM
Elhoff's Avatar
They are $65 at Rover Connection.
Old May 7, 2007 | 07:10 PM
ORIGINAL: Landzu
I don't under stand your post?
Mike
Old May 7, 2007 | 07:37 PM
discoken's Avatar
Hi I need to change my o2 sensors also. How do I know if I need 4 or 2 of them and which one's? Seems like there are a few of them for that year? I have a 1999 Disco 1. Thanks.
Old May 8, 2007 | 12:52 PM
ArizonaDiscovery's Avatar
Welcome to the club... I as well have a 99 Disco One. You will need four of the little buggers and the bad news is that you're going to be payin about 95 bucks each at roverconnection.com for them. Their prices seem to be the cheapest out there right now for them( now i know someone is going to reply and say "well you can use a generic and re-wire them---dont get me started) As was stated above, you should replace all four at once.
Old May 8, 2007 | 01:15 PM
StevenDiscoII's Avatar
On recommendation per DiscoMike, I replaced all four at 106K on my 2000 D2 during top-end rebuild. The right engine bank was showing black plugs, and the engine started to idle rough, however, all four is the way to go. [sm=smiley20.gif]
KlamathMatt
Apr 17, 2020 05:27 AM
jfoley1
Mar 18, 2009 06:52 PM
stupid
Nov 23, 2008 01:17 PM
jmccollister
Sep 9, 2008 08:50 PM
Morgan
Aug 14, 2007 08:15 PM
