O2 sensor harness repair
Ok so after my front diff snapped at the output flange on the pinion gear it banged up alot of stuff including my 2 O2 sensors upstream. Upon removing the passenger side clip if disinterested in my hand.
So i did a lot of googling and came upon this:https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And it fits perfectly. So if anyone needs to repair there O2 harness, here you go:
Ok so i finally got around to trying to fix the harness but i cant find in the rave what color pin goes where. So if anyone can help me out i would appreciate it.
Btw i know you cant really tell the color by the pic but i can by following the wires further up the harness.
Thanks. Used the info you provided and been driving for a bit now with no issues. I had to trace the wires all the way up to the firewall behind the intake manifold just to see what color they were. Also routed the wire far away from the exhaust manifold that gave me the benefit of 1 being away from heat and 2 easier access from underneath.
