O2 sensor lay lout
Old Aug 24, 2019 | 09:28 PM
lordmorpheus's Avatar
Originally Posted by Carlos Man
I’ll replace both upstream sensors, just found two Bosch for $110 on amazon.
Any tips on reaching and disconnecting the clip?
I usually use a long small flat screwdriver to release the harness clip and pull the harness off the metal bracket. Then, it is just a matter of uncoupling the sensor from the harness.
Old Aug 25, 2019 | 06:41 AM
mollusc's Avatar
don't use bosch o2 sensors. a lot of people have discovered them to be bad out of the box. look for the walker brand ones. they're also cheaper.
Old Aug 29, 2019 | 09:28 PM
Carlos Man's Avatar
Too late I had already ordered them :/
I did notice sensor 2 was an off brand from Japan, and sensor 1 was Bosch.
Old Aug 29, 2019 | 09:38 PM
Carlos Man's Avatar
Default Update:
If you have big hands this job is gonna be harder then you think.
After watching the Atlantic British do it yourself video, I figured this would be an easy job... granted it’s “easy” I’m a bigger guy with extra large hands.
My first issue was my 22 o2 sensor socket did not fit into the crevice to remove sensor 1 bank 1... had to use a 22 wrench instead.
From the undercarriage After maneuvering my way to press down-on the release tab I had to yank it for it to release on both front sensors. (Hate having to force things loose but pulling the wires was the only way for me to get them loose)
hardest part was reinserting the male end of the sensors. Because of the limited space I couldn’t maneuver my hands in a way to get the sensors attached.
What I ended up doing was having to patiently align them up from the bottom of the rover and take a long screw driver to press the sensor in.
Job took about 2 1/2 hours if anyone has any questions reach out.
Its do able obviously, but man I wish my girlfriend wouldn’t mind breaking a nail lol
Old Sep 15, 2021 | 02:38 PM
RoverSE7's Avatar
LOL I get my daughter to help with stuff like that because my Wife sure wont
ammonation
Aug 2, 2021 11:15 PM
cbwhitley
Jun 25, 2011 03:29 PM
Garrett
Feb 6, 2011 07:51 PM
NiteTrain
Nov 24, 2010 04:39 PM
bonedoc
May 1, 2007 06:49 PM
