O2 sensor problems
Old Jun 19, 2019 | 09:32 PM
Jcodisco2's Avatar
Default O2 sensor problems
Getting p0130 p0150 p0174 p1174
replaced front o2 nothing changed my short term fuel trim is 25 then 0 then back again on both. Ultra gauge shows voltage at .100-.035 upstream and downstream is .850 no idea what the problem is smells like raw fuel when in closed loop
Old Jun 20, 2019 | 01:05 AM
FlyingZebra34's Avatar
Try cleaning MAF maybe? Sometimes it's the simple stuff.
Old Jun 20, 2019 | 06:07 AM
Jcodisco2's Avatar
I tried replacing maf from parts vehicle and it did same thing
Old Jun 20, 2019 | 01:59 PM
redwhitekat's Avatar
Could be so many reasons but I had same issue
the connector sometimes gets gummed up or wires not in properly
also if you have a bad fuel purge valve and sticks open you dump vapours and in my case it made engine run like crap and stinks like raw fuel or just rotten eggs and throws the bank 1 sensor 1 code
also a good smoke test to make sure you don’t have vacuum and exhaust leaks
Old Jun 20, 2019 | 05:34 PM
Extinct's Avatar
Get the Torque app, an ELM327, and chart a graph of the 02. Did you swap left and right? Follow sensor? Check it when stone cold - if the sensor is any good it should go full .9-1.0 volt on cold start. If it doesn't, you have either a bad sensor or bad wires.
redrover75
Nov 18, 2018 02:26 PM
Soul97
Feb 16, 2014 07:20 AM
todd0765
Aug 20, 2012 09:19 PM
robdis96
Jul 5, 2007 01:02 PM
hoberock
Jan 6, 2007 09:51 PM
