OBD11 scanner question
Old Jul 9, 2007 | 03:42 AM
OlDood's Avatar
Default RE: OBD11 scanner question
Not trying to outdo anyone.. (okay, maybe a little) I bought the 3100 via Amazon for $94.
Old Jul 10, 2007 | 07:55 PM
gtagg's Avatar
so, just wondering, does this reader hook up to computer? does it tell you what the code is? can it tell you its a maf sensor or does it just give you a number.
gTAGG
Old Jul 11, 2007 | 01:59 AM
2000 Disco 2 SD7's Avatar
For complete description the 3110, go to: http://www.roverparts.com/Parts/D3110.cfm
Old Jul 11, 2007 | 09:57 AM
98roverguy's Avatar
Mine hooks up to my computer as well.
Old Jul 22, 2007 | 07:06 PM
Okay - got the scanner, plugged it in to my Landy and got only one code: P0171- system too lean (bank 1). So I cleared it from the computer which turned off the dash warning light, and drove it for about 100 miles and so far the service engine soon warning light has not turned back on nor does the scanner detect any new codes.
Does this mean I might be getting a false "lean system" warning ala the 3 amigos? And speaking of the 3 amigos, why didn't the Landy's computer have a record of the multiple 3 amigos warnings that I have been getting over the past several months?
This is more fun than my old Corvette
Old Jul 22, 2007 | 09:28 PM
okdiscoguy's Avatar
Goes through the ABS ECU, you need testbook to read it.
Old Jul 22, 2007 | 09:34 PM
Sorry but I'm not sure I understand your comment.....
Old Jul 22, 2007 | 10:47 PM
okdiscoguy's Avatar
3 amigo's are sometimes triggered by ABS fault codes which can not be read by an OBDII scanner, you have to have Testbook( The dealer diagnostic tool), or an Autologic Scanner, which will run you about $5K
Old Jul 23, 2007 | 10:57 AM
Thank you for the information on Testbook and Autologic. This will help me to not completely ignore future 3 amigo warnings, though I will test the abs in a safe environment to ensure it still works before taking my Landy to the dealer. As for the hill descent and traction control warnings, do they also route through the abs ecu, or will my equus obd II scanner acurately provide diagnostic information?
Regarding the "bank 1 - system too lean warning", does that sporadically occur when the gas cap is too loose or beginning to fail? Again, here I assume if it continues to appear then a MAF sensor replacement is in order.
Thanks again for all of the very useful information.
Dave
ShortTom
May 21, 2012 10:45 AM
bigdog1
Aug 18, 2008 07:04 PM
vjm530
Dec 22, 2007 11:30 AM
KevC
Jan 20, 2007 08:21 PM
Elhoff
Oct 31, 2006 10:38 AM
