Obd2 not responding with scan gauge
Old Dec 11, 2013 | 09:31 PM
Rover Rebel's Avatar
Default Obd2 not responding with scan gauge
I have a 2000 disco that just recently quit communicating with my scan gauge, It started acting funny a couple days ago by just displaying the volts but now just won't communicate I have tried it in my car and works just fine. Any ideas guys? Thanks
Old Dec 11, 2013 | 09:38 PM
jafir's Avatar
Fuse?
Old Dec 11, 2013 | 09:42 PM
Fuse seems to be good it lights up but won't communicate with it
Old Dec 11, 2013 | 09:52 PM
T.J.'s Avatar
Had a similar problem. Check fuse 20 in drivers panel. Third down on right row. If not that check ground wire.
Old Dec 11, 2013 | 10:02 PM
Thanks TJ, is there another ground besides the one on the drivers side foot panel?
Old Dec 12, 2013 | 09:10 PM
I think I have figured its a ground problem is there a way to splice in the ground wire on the obd2 plug and run a new wire?
Old Dec 13, 2013 | 09:21 AM
T.J.'s Avatar
Pin 4 is the OBD2 plug ground wire and the ground point is behind the drivers foot well carpet. This blog site is great: OBDII | Discovery 2 V8 - A budding enthusiasts story
Old Dec 13, 2013 | 12:30 PM
Thank you!
Old Dec 14, 2013 | 11:02 AM
Ok so I have over 12 volts and checked ground but even the hawkeye won't communicate, any I other ideas?
Old Dec 14, 2013 | 05:06 PM
acamato's Avatar
Any other issues? Dome lights, turn signals, working? I had an issue with the obd II port and it was related to corrosion issued with a header in the pass foot well.
