Obd2 not responding with scan gauge
Old Dec 15, 2013 | 10:18 AM
Rover Rebel's Avatar
Everything else works perfect and I can't seem to find any corrosion on anything
Old Dec 16, 2013 | 06:52 AM
acamato's Avatar
Did you cut away the harness covering on the pass footwell. the OBDII port is fed off header C0286 pin 16. The header is the gray located under the pass footwell the the left of the blower motor.. Check the RAVE for more info.
Here is some info from my experience:
https://landroverforums.com/forum/di...-repair-57435/
https://landroverforums.com/forum/di...il-data-58201/
Old Dec 16, 2013 | 07:27 AM
Acamato , I did finally cut the plastic off and it was full of water and corroded! Thank you so much for the help man!
wynhd
Mar 30, 2015 11:54 PM
Rover_Hokie
Feb 2, 2014 03:52 PM
LRD2&ME
May 4, 2011 02:04 PM
ChanchoVerde
Sep 23, 2009 08:53 AM
Benhamtroll
Jul 18, 2005 11:32 AM
