OBDII Code P1590
Old Apr 13, 2013 | 07:20 AM
You will need a scanner capable of reading the ABS codes if you want to correct the problem, do you have access to one?
Old Apr 13, 2013 | 09:56 PM
Isaiah08's Avatar
I sure don't was going to take to a mechanic to see if he could pin point the problem directly. Not positive but would it have an effect on my horse power or the way it idles? Seems to take hills slow and feels as if it wants to slow down quicker than it should? Also got that mass evap problem so stuck on what to tackle first!! Got codes 1590 and 0455 thought one may interfere with other. Maybe wheel sensors on 1590 and the 0455 was just going to do pressure smoke test and see where I go from there?!! Thanks Mike
Old Apr 13, 2013 | 10:07 PM
Isaiah08's Avatar
Also was wondering in the 1590 text it says hardware is not broken is that to mean that the sensors and ECU hardware are fine or just the ECU?
saltyrover
Apr 25, 2013 06:44 PM
sayeedA
Nov 15, 2011 11:02 PM
shearer60
Apr 11, 2008 01:26 PM
sanford
Nov 21, 2007 06:11 PM
navysar
Jul 12, 2007 05:18 PM
