OBDII reading question.??
Old Dec 3, 2008 | 07:46 PM
hazletbassist89's Avatar
Default RE: OBDII reading question.??
yeah I'd start by swapping the O2s and see what that does. Consider replacing the plugs and wires regardless. Use Magnecore 8mm wires or you'll be doing it again sooner than you want.
And it will actually be cheaper to run premium gas than regular because you lose a lot of mpg on regular.
Old Dec 4, 2008 | 03:06 AM
hollis's Avatar
plugs replaced.. CEL came on again driving back from work tonight.. Code says O2 too lean, Bank 1 O2 1. Ill try to swap out the front with the back O2 first.....hmmm I wonder if those O2 have a waranty? I got them from British Atlantic...???
Old Dec 4, 2008 | 09:27 AM
At your mileage, especially after all the cheap gas you have been running, replace all 4 02's Have you done the plug wires yet, if not do it using 8 mm Magnacor wires ONLY.
Your lean burn on should then go awy, if not start checking for a vacuum leak on the drivers side of the engine.
Old Dec 4, 2008 | 02:12 PM
hollis's Avatar
wel I replaced all 4 O2 about 8 to 10,000 miles ago. seems too soon for them to go bad just on 87octaine alone right? I have replaced the plugs, but not the wires yet.. Tomorrow, problem is that I have to drive it.. gave the wife my truck. I switched the O2 from one side to the other to see if the problem follows that O2 sensor.. any idea of a waranty on those O2 sensors? Im betting probably not!
Old Dec 5, 2008 | 12:10 PM
hollis's Avatar
OK so I swapped the front O2 and the problem followed.. Same O2... Im kinda pissed having to buy a new O2 sensor. Anyone else have this kind of problem of one burning out way too soon?
Old Dec 5, 2008 | 12:42 PM
Start burning the proper octane, you will get more power and about 1.5 more MPG.
Let us know if both the lean codes come back.
Old Dec 5, 2008 | 03:33 PM
hollis's Avatar
Will do.. I talked to British Atlantic, ordered a new one and they gave me a discount even though it was just over the year waranty... Does seafoam damage O2 sensors? Is there something I should do before I install the new sensor?
Street Wolf
Oct 12, 2011 12:06 PM
RobsRover
Nov 9, 2010 05:35 AM
2000 DII
Oct 20, 2008 08:40 PM
rover
Freelander
Apr 28, 2008 08:42 PM
leadoverdistance
Nov 20, 2007 05:06 PM
