OBDII scanner to reset gas cap fault?
Old Dec 29, 2008 | 12:30 PM
Rich 00 DISCO's Avatar
Default OBDII scanner to reset gas cap fault?
2000 Disco 126K. SES is illuminated due to gas cap being left open by attendant. I have closed correctly and have run through approximately 30 on-off cycles including a refill, but light remains on. I take care of the vehicle and am fairly sure that nothing else is going on - car runs fine - this happened once before and I stopped by my mechanic who reset it. Is there a sequence of "on-offs" that will reset this, or do I need to visit him again? I note that 3 rapid on-offs seemed to have reset SES after change of air filter triggered it, or was this coincidence?
Thanks!
Old Dec 29, 2008 | 01:58 PM
Default RE: OBDII scanner to reset gas cap fault?
First of all, 3 rapid restarts will not reset a check engine light, only fixing the problem then turn the codes off with a scanner.
Go get your codes read and get back to us with the exact 4 digit fault code.
Old Dec 29, 2008 | 03:25 PM
Gotcha - will do and respond. Thanks.
Soccer Dad
Jun 10, 2010 09:57 PM
leadfoot
Sep 14, 2009 05:00 PM
raptorial
Feb 2, 2009 09:09 PM
Elhoff
Oct 31, 2006 10:38 AM
