ODBII Errors & check engine
Old Oct 9, 2008 | 04:25 PM
Default RE: ODBII Errors & check engine
ptschram, so where do you think his next step should be? Go and get it scanned by the dealer? Drive it for a week? Set it on fire and roll it down a hill?
Old Oct 9, 2008 | 04:57 PM
ptschram's Avatar
ORIGINAL: Spike555
NEVER! Better to find an independent with a Rover-specific computer to rule out anomalous codes.
The Super-Scan allows one to use OBD-II parameters, occasionally, one will find a different response when using that function versus Rover-specific. The Rovacom-Lite and the T4 I also have never lead me wrong (although the T4 doesn't always want to talk to every truck).
Oxygen sensor codes can be very frustrating and time consuming, especially if you don't have a good handle on how the EMS works and a good way to read codes. It's expensive to throw parts at the problem as well.
Old Oct 9, 2008 | 05:00 PM
Ok, thats what I thought, he needs to go and have the codes read by a pro.
Thank you for clearing that up.
Old Oct 11, 2008 | 01:11 AM
jnice's Avatar
the code is P0160
o2 sensor 2/2 no data.
Old Oct 11, 2008 | 12:26 PM
There have been some wire harness issues, you may have one which then brings back your code.
TerryJ
Feb 10, 2016 02:51 PM
Traviss
Feb 16, 2015 05:46 AM
Linda_Mn
Defender
Jul 28, 2009 10:43 AM
*RANGER*
Mar 12, 2008 05:17 PM
bonedoc
May 1, 2007 06:49 PM
