Odometer light is out any way to fix?
Driving home tonight I noticed the light for the odometer is out. The spedometer light works, and the digital milage shows, just the light for the milage is out. Other than being a little annoying at night, it's not a big deal, just wondering if there is any way to fix it.
I was just looking in the shop manual and it said that "A photocell controls the illumination of the LCD, maintaining contrast of the display during ambient light changes." Right now my dash is lit up like a christmas tree because of a bad ABS sensor, I'm wondering if the lit up warning lights are making the photocell think that it's daylight out thus keeping the odometer light from coming on. At least thats what I'm hoping, ha ha. I guess I'll see what happens after I replace the ABS sensor and the warning lights go out.
I know its primary function is an input for the automatic climate control, not entirely sure if the odometer uses it as well. I always assumed (maybe incorrectly) that the photoelectric sensor on the mirror was for controlling light intensity.
(From RAVE pg 1204)
Sunlight sensor
The sunlight sensor consists of two diodes that provide the ATC ECU with inputs of light intensity, one as sensed
coming from the left of the vehicle and one as sensed coming from the right. The inputs are used as a measure of the
solar heating effect on vehicle occupants. The sensor is installed in the centre of the fascia upper surface.
(From RAVE pg 1204)
Sunlight sensor
lipadj46
07-08-2009 07:41 PM
