Odometer Light
Old Aug 25, 2008 | 09:11 PM
bookerbr's Avatar
Default Odometer Light
My light behind the odometer just went out and I was wondering if anyone knows how to fix it. I replaced the light behind the clock and was wondering if it is similar. Thanks
Brian
Old Aug 25, 2008 | 09:55 PM
Default RE: Odometer Light
You need to remove the instument cluster. Lower your tilt steering wheel as low as it goes and you will find two small screws, then the cowling will come off. Then you can replace the bulb.
Old Sep 6, 2008 | 10:16 AM
bookerbr's Avatar
Ok, I was able to get the bulb out but I can't find a replacement anywhere. It says toshiba V-2 on the back but it doesn't help. Does anyone have any idea where to find the replacement bulbs that goes behind the odometer?
Brian
Old Sep 6, 2008 | 10:36 AM
Have you gone toRadio Shack? Otherwise the dealer.
The brand of bulb makes no difference, just make sure that you get the correct wattage.
Old Dec 5, 2013 | 12:51 AM
JimBonner8's Avatar
7th Gear
Have a look at this link. It covers replacement for most all instrument related bulbs. It is light on how to access the odometer backlight & main cluster but it provides, photos, bulb part numbers & descriptions for each bulb. Brilliant!
Disco 2: Replacing dashboard, ATC and digital clock bulbs - Australian Land Rover Owners
Old Dec 5, 2013 | 07:24 AM
drowssap's Avatar
JimBonner8
Welcome you should check the last date of posts that you are responding too, the last response to this post was in 08.
nice link
san988
Dec 16, 2014 02:38 PM
shagybruce
Jan 2, 2013 09:56 PM
ZB-30
Jul 13, 2012 01:23 PM
stephen
Apr 12, 2005 01:57 AM
discodataway
Mar 25, 2005 05:40 PM
