OEM 180 Thermostat failed shut!
Hmm I would spend a few bucks on a coolant tester for combustion gases
https://www.amazon.com/Lisle-75500-C...coolant+tester
The coolant system is in perfect working order. The trouble is it is being pressurized quickly and forcing the coolant to puke from the reservoir. It will idle for 30-45 minutes at 195. Drive it for 2 minutes, and it quickly approaches 230 and pukes all the coolant out. I believe head gaskets are wishful think at this point. It very well may be a cracked block.
on
overheated Rover, often leading to tragic conseqences.
Well, heading home Sunday night my temp light kicked on very fast. Ultragauge read 250°! Shut it down immediately and got it towed. Coolant puked from the reservoir and the top hoses were hard. No heat from the vents. The oem 180 thermostat was only one year old. Head gaskets were done 30,000 miles ago. Do you think I'm OK? Again, I shut it down immediately and had it towed home. New thermostat should arrive tomorrow. I'm a bit nervous. I hope there is no damage.
Thermostats can, and do, sometimes go bad in a heartbeat, sticking open or closed. I have seen that happen many times in family, over past 50+ years. That is why, a long time ago, I installed an inline thermostat on my Rover, using a cheap Chevrolet 180 deg. thermostat, available anywhere, any small town America. As we all know, heat is a huge enemy of all aluminum block engines, especially the Rover V8, due to extremely thin aluminum walls between the water jacket and the cylinder liners. That thin wall aluminum, under excess heat, is likely to crack, usually just beneath the bottom of one or more of the threaded head bolts, between the water jacket and the liner, which otten leads to the liner(s) loosening up, and slipping up/down, in sequence with pistons. Thus, you have every reason to be "a bit nervous." After you determine, for certain, the extent of any possible damage, please let us know.
CollieRover
06-18-2020 01:05 PM
cosmiccharlie
06-05-2013 10:09 PM
