Oem or aftermarket parts from AB?
Old Dec 26, 2011 | 04:53 PM
SolbergFanBoi's Avatar
Originally Posted by jafir
That is ONE area where I will agree with you that the D1 is better than the D2... this stupid cooling system we have.
I still blame the EPA, and not Land Rover.
I wouldn't say that is the only advantage... Misalignment of the front cover/oil pump, no CDL, front prop shaft issues to just name a few. The 4.6 seems to be a far less reliable engine than the 4.0l but then again, that's not saying much when compared to other engines by other manufacturers
Old Dec 26, 2011 | 05:14 PM
jafir's Avatar
I don't think my 4.6L has had any issues with the oil pump... but I did just buy a set of gears from AB, because the price has gone up everywhere else. Just in case. My front propshaft looked fine when I "rebuilt" it, at 120,000+ miles. And I plan on stealing the CDL out of my 99 before I sell it.
I think these trucks get a bad rep. from people just complaining about the problems. One thing I will say about a Motronic engine over the GEMS engine is that the D2 either runs, or it doesn't (cranks sensor) and does a good job of spitting out codes for problems. The GEMS will run like crap, and never spit out a code.
Old Dec 26, 2011 | 05:31 PM
Don't get me wrong, I love my DII. I had a DI and my dad has a Defender so my loyalty to the brand has pretty consistent. No defending a motor no matter who it's built by for the kind of premature problems these V-8's have. It's a ****ing joke really...
Old Dec 26, 2011 | 05:35 PM
I agree 100% BUT I think there are times when it is adventagious to have a crappy running engine rather than one that either runs or doesn't...such as when a chainsaw ax murdererrrreeerrere guy is chasing you.
Old Dec 26, 2011 | 05:50 PM
jafir's Avatar
I blame California on that... and maybe the EPA too. I think Dexcool and higher engine temps to reduce emissions are what makes the D2 engine fail more often.
Coolant should be changed every two years, not every time you replace the engine.
Old Dec 26, 2011 | 06:07 PM
Haha I hear that!!! I however don't blame CA for misaligned dowels on the front cover and failed oil pumps Or head gaskets every 90k miles!
Old Dec 26, 2011 | 06:59 PM
DiscoRover007's Avatar
I don't think the old buick v-8 is that bad but man does Land Rover makes some ****ty gaskets and seals. I never seen a car leak more for any other reason than just because.
Would be cool if the D2 had 300 HP though.
Old Dec 26, 2011 | 08:26 PM
Rovin4life's Avatar
actually the failures for the head gaskets are from the pcv separator getting stuffed and the pressure building till it pops a gasket. Seen the pressure build so high on bosch engines that the intake gasket goes from concave to convex. Also alot of the oil failures on higher mileage vehicles on the 4.6 was from the lack of an engine oil cooler. notice how the 3 and 04 models lack the oil cooler line. You still get the head gasket leaks its not as bad with the newer bosch engines.
OEMPartHaus.com
Member Group And Special Buys
May 28, 2015 08:59 AM
CUpgt
Apr 26, 2013 02:55 PM
AxeAngel
Jan 16, 2008 01:40 AM
Tungus
Audio/Visual Electronics
Feb 2, 2007 11:12 PM
Broms
Dec 13, 2004 10:37 PM
